Hubert, re...
> -- On Mar 27, 1998, [email protected] (Tim Mooney) wrote
> > I should mention that glitches on the limit-switch lines can produce
> > very similar behavior, and are by **far** the more common cause of it.
> > So don't everybody with an intermittently jerky motor immediately assume
> > their hardware is flakey. You might just need some decoupling capacitors.
> I'm not sure that this is true. I've seen this behavior very regularly
> (with the .27 release of the motor record, VME8-8 board). I don't have
> any limit switches in my system and limit-switch support has not been
> enabled.
Wait a minute. You can't enable or disable limit switch support, and the
hardware doesn't care whether or not you actually have switches.
Tim
- Re: Stops in the motor record larry
CA Server john sinclair
<1998>
2025
2026
Re: Stops in the motor record Guy Jennings
<1998>
2025
2026
