1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA Server
To: "'john sinclair'" <[email protected]>, tech talk <[email protected]>
Date: Tue, 31 Mar 1998 17:19:34 -0600
John,
Do you consider this a total fix?  I tested this out and it does work as
long as excas is run on the same node that you do the ca_test from.  I
set up to test this and if I run both of these on the same machine I get
good results.  If I run ca_test (or some other ca utility) on another
machine, I get a message that fred was not found.  This seems similar to
the problem that I had when looking over this with Jeff Hill.  I even
think that this may have been the same variable that we set to get it to
work through localhost.
John
> -----Original Message-----
> From:	john sinclair [SMTP:[email protected]]
> Sent:	Tuesday, March 31, 1998 1:05 PM
> To:	tech talk
> Subject:	Re: CA Server
> I have found a solution:
> There is an environment variable named EPICS_CAS_INTF_ADDR_LIST
> that may be set to the node address from which CA Server is
> running. It is nice having the source code!
> > I have built epics base under redhat linux 5 and am trying to
> > run an example CA Server, excas, as follows:
> > caRepeater &
> > excas &
> > At this point netstat shows a process listening on udp socket 5064.
> > I then run the utility ca_test as follows:
> > ca_test fred
> > >From another window, tcpdump sees the broadcast messages
> > from ca_test, but excas never seems to respond.
> > Any suggestions?
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 423-576-6362
> 423-574-1268 (fax)
RE: CA Server john sinclair
Prev: Re: CA Server Maren Purves
Next: EPICS and WindRiver's Tornado Rosemary Alles
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA Server Rozelle Wright
Next: RE: CA Server john sinclair
