1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: exporting waveforms
To: [email protected]
Cc: [email protected]
Date: Tue, 7 Apr 98 10:11:55 CDT
The reason why et_wish is slow is because of the update mechanism
it uses to respond to CA monitors (the X event loop).  This says
nothing about the involvement or performance of BLT.  BLT was mentioned
because it has support for "vectors" (which are used by et_wish to gather
waveforms from CA).  In the upgrade of BLT, the vector interface
was changed and nobody has yet updated et_wish to reflect these changes.
In the version of et_wish that I have, support for vectors was commented out.
Other EPICS-to-Tcl/Tk interfaces may exist, such as yours, which
have better performance than et_wish.  Maybe, with a little bit of work,
et_wish can be improved with regards to update rate, as well as including
support for Tcl/Tk v8 and BLT v8 (when it becomes available).
   Pete
Johannes van Zeijts wrote:
> Pete Jemian wrote:
> > Do not advise using et_wish for this type of work.
> > Since BLT was upgraded ... is very slow when you have
> > a high update rate, such as with a strip chart or plotting
> > tool.
> I have used the BLT extension to tcl/tk with great success
> (both for own use and
> in the control room). You ofcourse have to write the interface
> code in C instead
> of only using tcl. After you do that correctly you can get as
> fast live updates as
> StripTool or any other X11 plotting tool, with the same cpu usage.
> There is
> definitely no inherent slowness to BLT, and as you note it gives
> you a lot more
> flexibility than hardwired plotting code.
> All my interface code at the moment runs through CDEV, but I can
> show you the code
> if you are interested.
> 	-Johannes
Prev: XFree86 and Motif... Bonnie Madre
Next: Fast Programming of Boot/Flash Memory Till Straumann
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: exporting waveforms Bob Dalesio
Next: RE: exporting waveforms Ben-chin K. Cha
