--- Begin Message ---
Well, probe, StripTool, cau, caget, caput, and most of the stuff that I
want to use are now working away under Linux 5.0. Medm compiles, but
I get a lot of complaints of the type listed below. In addition, it
crashes with the following message: (I expected the font problem, but
not the BadWindow message)...
medmInit: Unable to load font widgetDM_4
Trying fixed (default) instead
medmInit: Unable to load font widgetDM_6
BadWindow (Invalid window parameter)
SIGSEGV
MEDM Version 2.3.3 Loading aliased fonts...Aborted
Am I missing something, or do I have the wrong version of something?
(RedHat Linux 5.0, RedHat Motif 2.1, XFree86 3.3.2, MEDM 2.3.3)
These are the messages I get while the files in the xc directory are
compiling:
make[1]: Entering directory `/usr/local/epics/extensions/src/medm/xc'
Linux: install
make[2]: Entering directory `/usr/local/epics/extensions/src/medm/xc/O.Linux'
rm -f BarGraph.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../BarGraph.c
rm -f Caption.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Caption.c
../Caption.c: In function `Initialize':
../Caption.c:236: warning: passing arg 1 of `XtName' from incompatible pointer type
rm -f Clip.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Clip.c
../Clip.c: In function `Redraw':
../Clip.c:182: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
rm -f Control.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Control.c
rm -f Indicator.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Indicator.c
../Indicator.c:156: warning: initialization from incompatible pointer type
../Indicator.c:168: warning: initialization from incompatible pointer type
../Indicator.c:169: warning: initialization from incompatible pointer type
../Indicator.c:170: warning: initialization from incompatible pointer type
../Indicator.c:171: warning: initialization from incompatible pointer type
../Indicator.c:179: warning: initialization from incompatible pointer type
rm -f Matrix.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Matrix.c
../Matrix.c:556: warning: initialization from incompatible pointer type
../Matrix.c:557: warning: initialization from incompatible pointer type
../Matrix.c: In function `ScrollVertCB':
../Matrix.c:3339: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `ScrollHorizCB':
../Matrix.c:3518: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `AddRows':
../Matrix.c:6013: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `DeleteRows':
../Matrix.c:6104: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `AddColumns':
../Matrix.c:6199: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `DeleteColumns':
../Matrix.c:6295: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `SetRowColors':
../Matrix.c:6376: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `SetColumnColors':
../Matrix.c:6466: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
../Matrix.c: In function `SetCellColor':
../Matrix.c:6548: warning: passing arg 1 of `XtWindowOfObject' from incompatible pointer type
rm -f Byte.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Byte.c
rm -f Meter.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Meter.c
../Meter.c:8: warning: `_GNU_SOURCE' redefined
*Initialization*:1: warning: this is the location of the previous definition
../Meter.c:149: warning: initialization from incompatible pointer type
../Meter.c:161: warning: initialization from incompatible pointer type
../Meter.c:162: warning: initialization from incompatible pointer type
../Meter.c:163: warning: initialization from incompatible pointer type
../Meter.c:164: warning: initialization from incompatible pointer type
../Meter.c:172: warning: initialization from incompatible pointer type
rm -f Value.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../Value.c
rm -f utils.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../utils.c
rm -f version.o
gcc -ansi -O -I/usr/X11R6/include/X11 -I/usr/X11R6/include/X11 -D_GNU_SOURCE -D_X86_ -Dlinux -I. -I.. -I../../../../../base/include -DUNIX -c ../version.c
Building library libANLwidgets.a
rm -f libANLwidgets.a
ar r libANLwidgets.a BarGraph.o Caption.o Clip.o Control.o Indicator.o Matrix.o Byte.o Meter.o Value.o utils.o version.o
ranlib libANLwidgets.a
Installing library ../../../../../extensions/lib/Linux/libANLwidgets.a
INSTALL_PRODUCT = ../../../../../base/bin/Linux/installEpics *********
make[2]: Leaving directory `/usr/local/epics/extensions/src/medm/xc/O.Linux'
make[1]: Leaving directory `/usr/local/epics/extensions/src/medm/xc'
Bonnie Madre
Accelerator Development
Integration and Assessment Group
ANALOG ADDRESS:
Thomas Jefferson National Accelerator Facility (TJNAF)
MS 58
12000 Jefferson Avenue
Newport News, VA 23606
(757) 269-7059
E-MAIL ADDRESS:
[email protected]
--- End Message ---
RE: CA Server (default configuration behaves strangely on linux) Jeff Hill
CapFast Release Notes Dr. Chong Lee
<1998>
2025
2026
Re: MEDM on LINUX madre
<1998>
2025
2026
