1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [Q or Help!] change of scanning period causes IOC crash.
To: [email protected]
Date: Thu, 4 Jun 1998 22:59:23 +0900
 Thank you Jeff. After I sent the previous e-mail, my colleague found that
reduced size of buffer area removed the problem. In the original program,
he used rather big array (20Kbytes) in the subroutine for reading data from VXI.
It was necessary at somepoint, but the current version can work with
smaller buffer size.  And this version works very well.
Thanks again to all of you.
 Noboru YAMAMOTO
 KEKB control group
 KEK, JAPAN
Jeff wrote:
>Noburo,
>As I recall, APS experienced some problems with the National Instruments
>MXI hardware timing out during VXI bus transfers when they first set up their
>MXI systems. Ned Arnold ([email protected]) might be able to provide some hints on
>setting up MXI bus systems.
>Jeff
>On Tuesday, June 02, 1998 2:08 AM, Noboru Yamamoto [SMTP:[email protected]] wrote:
>> Hi,
>>  We are writing a device support routines for a VXI oscillo scope. We use
>> MXI-bus connection to cnnect VME bus, where IOC is, and VXI bus , where
>> an Osciloscope. When you satrted databse at one scanning period, the device
>> support works OK. Some records send commands to setup measurement and a
>> waveform record reads trace data from the osciloscope.
>> However, we changes scanning period of the processing, IOC crashes.
>> Actually it freeze.
>>  Does anybody has a similar problem in developing device support? Which part
>> of device support we should look at?
>>  Your comments will be grately appricated.
Prev: TCL/TK interface to Channel Access William L. Cruise
Next: TCL/TK interface to Channel Access Janet B. Anderson
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: [Q or Help!] change of scanning period causes IOC crash. Jeff Hill
Next: VME Power PC & epics r3.13.b11 Mauro Giacchini
