1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA client suspend
To: [email protected]
Date: Wed, 17 Jun 1998 10:58:51 EDT
Hi gentlemen,
I got the message below when I experimented with Access Security:
>CA client: A call to "assert (status == 0 || status == S_asLib_asNotActive)" failed in ../camessage.c at 1289
>Please send a copy of the output from "tt (0x1e1ad0)" and a copy of this message
>to the author or "[email protected]"
>This problem occurred in "@(#)Version R3.13.0.beta.11 $$Date: 1997/10/15 14:41:16 $$"
>task: 0X273d28 taskwd
>task 1e1ad0 CA client suspended
Output from "tt ..." is following:
>-> tt (0x1e1ad0)
> 5f3c8 _vxTaskEntry   +10 : _camsgtask (b, 0, 0, 0, 0, 0, 0, 0, 0, 0)
>2e40f2 _camsgtask     +342: _camessage (215fe8, 21a044)
>2e4406 _camessage     +1a0: 2e5496 (21a054, 215fe8)
>2e5654 _write_notify_reply+8ac: _epicsAssert (2e41f7, 509, 2e5443, 0)
>2f01c2 _epicsAssert   +82 : _taskSuspend ([1e1ad0, 2f0120, 2f00e5, 21a054, 17])
>value = 0 = 0x0
This happened under such circumstances:
At first I booted IOC with Access Sequrity disabled.
Then on the IOC console I typed:
asSetFilename("<my Access Sequrity configuration file>")
and then:
asInit
At first it looked OK. When I tried to perform CA put (using "caput" command
from Unix) from host which didn't have write permission in AS config file
I got error message that "caput failed". While from the host having write
permisssion this command executed successfully. And then I tried to open
an MEDM display dealing with channels in my IOC. I did it on the host with
write permissions. And after this attempt I got this message and MEDM display
couldn't connect to channels.
  If this information helps, i'll be glad.
Best regards,
V.Korobov.
Re: CA client suspend Marty Kraimer
Prev: Re: CA client suspend Marty Kraimer
Next: boot problems & related on hkbaja47 Maren Purves
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Postscript version of the record reference manual Bob Dalesio
Next: Re: CA client suspend Marty Kraimer
