1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Xycom 566 waveform
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Fri, 19 Jun 1998 07:02:08 -0600 (MDT)
After reading back through the code - it seems to me that the Xy566
waveform is set up to use an external trigger for each sample. This
was accomplished with an 085 board that was designed at LANL (as I
recall). To use the 566 as an array you would need to:
1) 566 short address space to 9000
2) 566 standard IO space to 80000
3) remove the need for an 085
(Number 3 may be as easy as removing the need in the xy566_init routine
or may require setting something different in the init sequence so that
instead of an external trigger for each value - it uses only one trigger
to reset it - I could look into this further at a later time.)
	Bob
Xycom 566 waveform Garrett D. Rinehart
Prev: base release baseR3.13.0.beta12 Marty Kraimer
Next: medm: leading zeros Paul Sichta
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Xycom 566 waveform Garrett D. Rinehart
Next: Looking for BLT1.7 Brian McAllister
