1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA monitor function pb
To: "'J.F. Gournay'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 17 Jul 1998 08:51:36 -0600
Jean-Francois,
We have not seen symptoms of this nature here. Please send an extract from
your source code that reproduces this problem, and some details about the operating
system in use when this problem occurred. Thanks for bringing this to our attention.
Jeff
On Friday, July 17, 1998 3:47 AM, J.F. Gournay [SMTP:[email protected]] wrote:
> Hello to all the CA gurus,
> I have a list of Waveform records.
> A C user function (USERFUNC declared with ca_add_array_event) is used to monitor
> these channels. The USERARG parameter of ca_add_array_event is used to identify
> the record which causes the call of the USERFUNC.
> At the initialization, USERFUNC is normally called with the different USERARG
> corresponding to all the waveform records.
> But after this, USERFUNC is always called with the last USERARG as declared by
> ca_add_array_event whatever the processed waveform record.
> I run R3.12.2.
> Many thanks for any help.
> J.F. Gournay
>                                 |  Jean-Francois Gournay               |
>                                 |  DAPNIA/SIG                          |
>                                 |  CEA-Saclay                          |
>                                 |  F-91191 Gif-Sur-Yvette CEDEX        |
>                                 |  Phone : +33 (0)169087032            |
>                                 |  Fax   : +33 (0)169086301            |
>                                 |  E-Mail:  [email protected]            |
Prev: CA monitor function pb J.F. Gournay
Next: strange error compiling C++ code under EPICS Elaine Best
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
