1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Setting States for an MBBI Record
To: [email protected]
Cc: [email protected]
Date: Thu, 30 Jul 1998 14:41:35 -0500
> I set up the ZRVL thru FFVL fields to correspond to these numbers and
> set the corresponding strings ZRST thru FFST to be the string
> descriptions for the 16 states.
> For the first three values (0, 1, 2) the behaviour is as expected -
> the ZRST, ONST and TWST strings as displayed. But inputting a 3
> (where THVL=4) displays the THST! Inputting a 4 displays the FRST
> and on and on all the way up to 15. Entering a value larger than 15,
> e.g. the value 16384 which is assigned to FTVL, leads to the string
> "INVALID VALUE" being displayed.
It sounds like you might have DTYP as "Soft Channel" instead of
"Raw Soft Channel".
	Ned
Re: Setting States for an MBBI Record Dayle Kotturi
Prev: Setting States for an MBBI Record Dayle Kotturi
Next: Re: Setting States for an MBBI Record Dayle Kotturi
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
