Hi Everyone,
I'm sure Jeff will answer this as soon as he gets in.
The problem is that the newest patch for tornado has modified an include
file h/net/mbuf.h by including the define
#define m_type mBlkHdr.mType
It is included in some of the network files that channel access uses
and conflicts with a field name m_type in Jeff's channel access code
I believe he is working on a solution and should send out a message later
this morning.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs LANSCE-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
> From [email protected] Tue Aug 4 08:14 MDT 1998
> To: <[email protected]>
> Subject: R3.13.0.beta12 + PPC MV2306 + VxWorks 5.3.1 (Tornado 1.0.1) + Solaris 2.6
> Date: Tue, 4 Aug 1998 15:07:35 +0100
> Mime-Version: 1.0
> X-Priority: 3 (Normal)
> X-Msmail-Priority: Normal
> X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
> Importance: Normal
> X-Mimeole: Produced By Microsoft MimeOLE V4.72.2106.4
> Content-Transfer-Encoding: quoted-printable
> X-Mime-Autoconverted: from 8bit to quoted-printable by mailgate.ll.iac.es id PAA14448
> X-Lines: 119
> Content-Type: text/plain; charset="iso-8859-1"
> Content-Length: 5345
> Hi all,
> We are compiling EPICS 3.13.0.beta12 for a PPC board MV2306 with
> VxWorks 5.3.1 (Tornado 1.0.1) under Solaris 2.6.
> We are having the following compilation error in the ca (channel access)
> directory:
> gnumake[3]: Entering directory
> `/usr/epics/R3.13.0.beta12/base/src/ca/O.mv2306'
> rm -f iocinf.o
> /usr/wind/host/sun4-solaris2/bin/ccppc -B/usr/wind/host/sun4-solaris2/lib/gc
> c-lib/ -nostdinc -ansi -pedantic -O -Wall -DCPU=PPC604 -DMV2300 -mstrict-
> align -DCPU_FAMILY=PPC -DTRUE=1 -DvxWorks -DV5_vxWorks -fno-builtin -I. -I
> .. -I../../../include -I../../../include/os/vxWorks -I/usr/wind/target/h
> -c ../iocinf.c
> In file included from ../iocinf.h:205,
> from ../iocinf.c:138:
> ../caProto.h:241: syntax error before `.'
> ../iocinf.c:133: warning: `sccsId' defined but not used
> ../os_depen.h:36: warning: `os_depenhSccsId' defined but not used
> gnumake[3]: *** [iocinf.o] Error 1
> gnumake[3]: Leaving directory
> gnumake[2]: *** [buildInstall.mv2306] Error 2
> gnumake[2]: Leaving directory `/usr/epics/R3.13.0.beta12/base/src/ca'
> gnumake[1]: *** [ca.buildInstall] Error 2
> gnumake[1]: Leaving directory `/usr/epics/R3.13.0.beta12/base/src'
> gnumake: *** [src.buildInstall] Error 2
> I can't find where the syntax error comes from.
> I compiled the same EPICS 3.13.0.beta12 for 68k (mv147) and VxWorks 5.2 with
> no problems, so the syntax error doesn't show.
> Also, Steve Lewis noted that the size of some files is our src/ca directory
> is not equal to their files for the same version.
> I just downloaded the 3.13.0beta12 version from the Web and I didn't find
> any
> patch:
> -rw-r--r-- 1 epics control 1737165 jul 25 18:06 R3.13.0.beta12.tar.gz
> Are the following src/ca files of the CA the last version for 3.13 ?
> total 914
> drwxr-xr-x 5 epics control 1024 agto 3 12:45 .
> drwxr-xr-x 28 epics control 512 jul 25 22:10 ..
> -r--r--r-- 1 epics control 74258 jun 18 15:40 access.c
> -r--r--r-- 1 epics control 27938 jun 18 15:40 acctst.c
> -r--r--r-- 1 epics control 898 jun 18 15:40 addrList.h
> -r--r--r-- 1 epics control 5275 jun 18 15:40 bsd_depen.c
> -r--r--r-- 1 epics control 3974 ab 10 1997 BUILD_VMS.COM
> -r--r--r-- 1 epics control 93 jun 18 15:40 ca.def
> -r--r--r-- 1 epics control 34292 jun 18 15:40 cadef.h
> -r--r--r-- 1 epics control 8507 jun 18 15:40 caerr.h
> -r--r--r-- 1 epics control 786 eno 25 1996 caeventmask.h
> -rwxr-xr-x 1 epics control 8943 jul 28 00:26 caProto.h
> -r--r--r-- 1 epics control 634 jun 18 15:40 caRepeater.c
> -r--r--r-- 1 epics control 10602 jun 18 15:40 catime.c
> -r--r--r-- 1 epics control 22573 jun 18 15:40 conn.c
> -r--r--r-- 1 epics control 49903 jun 18 15:40 convert.c
> -r--r--r-- 1 epics control 1388 ab 10 1997 evtime.c
> -r--r--r-- 1 epics control 2339 may 5 1997 flow_control.c
> -r--r--r-- 1 epics control 663 agto 5 1993 future_work.txt
> -r--r--r-- 1 epics control 7438 jun 18 15:40 if_depen.c
> -rwxr-xr-x 1 epics control 45054 jul 29 20:03 iocinf.c
> -rwxr-xr-x 1 epics control 21550 jul 29 20:04 iocinf.h
> -r--r--r-- 1 epics control 82 jun 28 1996 Makefile
> -r--r--r-- 1 epics control 1141 jun 18 15:40 Makefile.Host
> -r--r--r-- 1 epics control 468 nbre 2 1996 Makefile.Vx
> -r--r--r-- 1 epics control 5420 jun 18 15:40 net_convert.h
> drwxr-xr-x 2 epics control 512 agto 3 12:45 O.mv2306
> drwxr-xr-x 2 epics control 512 agto 3 12:53 O.solaris
> -rwxr-xr-x 1 epics control 2859 jul 28 00:15 os_depen.h
> -r--r--r-- 1 epics control 5198 jun 18 15:40 posix_depen.c
> -r--r--r-- 1 epics control 12896 jun 18 15:40 repeater.c
> -r--r--r-- 1 epics control 24439 jun 18 15:40 service.c
> -r--r--r-- 1 epics control 12016 jun 18 15:40 syncgrp.c
> -r--r--r-- 1 epics control 2031 jun 18 15:40 test_event.c
> -r--r--r-- 1 epics control 2970 dbre 19 1995 ucx.h
> -r--r--r-- 1 epics control 1671 nbre 14 1994 V5_vxWorks_patch.c
> -r--r--r-- 1 epics control 6897 jun 18 15:40 vms_depen.c
> -r--r--r-- 1 epics control 21746 jun 18 15:40 vxWorks_depen.c
> -r--r--r-- 1 epics control 18325 jun 18 15:40 windows_depen.c
> One more question: our Wind River Systems representative says that
> the BSP for the MV2306 is exactly the same as for the MV2304.
> Is that true ?
> Many thanks.
> Regards,
> Marti
> Martí Pi i Puig [email protected]
> GTC Control Group (GRANTECAN, S.A.) http://www.gtc.iac.es
> Instituto de Astrofísica de Canarias http://www.iac.es
> c/ Vía Láctea s/n Phone: 34-922-395137
> 38200 La Laguna (Tenerife) Fax: 34-922-315032
R3.13.0.beta12 + PPC MV2306 + VxWorks 5.3.1 (Tornado 1.0.1) + Solaris 2.6 Martí Pi
RE: R3.13.0.beta12 + PPC MV2306 + VxWorks 5.3.1 (Tornado 1.0.1) + Solaris 2.6 Jeff Hill
<1998>
2025
2026
<1998>
2025
2026
