1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Resman problems...
To: [email protected]
Cc: [email protected]
Date: Fri, 07 Aug 1998 15:38:32 +0100
[email protected] wrote:
> We have been attempting to run Resman on our baja 68060, but we run
> out of memory.  We don't think it is a software problem, as the program runs
> just fine on a similar system.
What is the output from memShow when only vxWorks is loaded?  Does it
show the amount of RAM you think you have installed in the system?
You have defined these extra memory areas within sysPhysMemDesc and I
presume they maps onto several 32Mb VME RAM cards, but is this RAM being
added to the memory blocks being managed by the system anywhere?  For
each RAM area listed other than the default memory partition you need to
call memAddToPool, either somewhere in usrRoot(), elsewhere in sysLib.c
or in your startup script. Without these calls, vxWorks will not know
that it is in charge of these memory areas so will never allocate memory
from them.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Resman problems... donner
Prev: Resman problems... donner
Next: tsDefs.... Bonnie Madre
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Resman problems... Jeff Hill
