Using a slightly modified version of caExample (which comes with
makeBaseApp), I download 200 parameters to a waveform record using a
ca_array_put command.
The record is defined as:
record(waveform, "$(user):waveForm1")
field(DESC, "waveform record")
field(NELM, "200")
field(DTYP, "Soft Channel")
field(FTVL, "USHORT")
from caExample.c, I do:
SEVCHK(ca_array_put(DBR_SHORT,200,mychid,(void *)indata),"ca_array_put
failure");
SEVCHK(ca_pend_io(5.0),"ca_pend_io failure");
SEVCHK(ca_array_get(DBR_SHORT,200,mychid,(void
*)outdata),"ca_array_get failure");
I set the data equal to the array index, e.g. outdata[50] =50. I
have defined the indata and outdata to be pointers to short.
When I read-back the data, on the sgi OS, I get back exactly
what I expect. When I read-back data on Linux (Red Hat 5.0), I get the
correct answer for the first 128 elements, for elements following 128, I
get:
outvalue = invalue | 0xff00
e.g. for outdata[199]= 65479 = 0xffc7
(for those not hex-speaking 0xc7 is 199)
I have checked to see that the correct values are in the waveform
record, and they are (the ca_array_put command works correctly). However,
when the ca_array_get is called, the values for the elements greater than
128 are corrupted when they are returned on the Linux box -- but NOT on
the sgi.
Any ideas?
Jeff
_____________________________________________________
Jeffrey McDonald, Florida State [email protected]
FNAL MS 352 phone 630-840-3983
Batavia, IL 60510 fax 630-840-8886
Re: pop-up menu problems in MEDM 2.3.4a Ken Evans
RE: strange ca_array_get results on Linux Jeff Hill
<1998>
2025
2026
Re: MEDM pop-up menus ... Pete Jemian
<1998>
2025
2026
