1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Mvme167-35b
To: Li Jingyi <[email protected]>
Cc: [email protected]
Date: Thu, 10 Sep 1998 08:03:07 -1000
Li Jingyi wrote:
> Hi all,
> We have a newely bought Mvme167-35B card with 32MB memory.
> When I plug it in the crate and boot, the system halt.
> The vxWorks we currently use is 5.1 version. The following
> is the information on the console:
> boot device          : ei
> processor number     : 0
> host name            : joca
> file name            : /usr/VxWorks_5.1/vw/config/mv167/vxWorks
> inet on ethernet (e) : 152.3.54.5:ffffff00
> host inet (h)        : 152.3.54.3
> user (u)             : epics
> flags (f)            : 0x0
> target name (tn)     : orbit
> startup script (s)   : /usr/applications/ioc/st.cmdmv167
> Attaching network interface ei0... done.
> Attaching network interface lo0... done.
> Loading... 369412 + 103168 + 26458
> Starting at 0x1000...
> Has anyone ever met such a problem and can give me some advise?
Seen this too many times ...
suggestions:
- check if you have an .rhosts file, and if the host that you are
booting from is in it
- check that you DON't have a line
setenv EPICS_CA_AUTO_ADDR_LIST "NO"
(and a subsequent  EPICS_CA_ADDR_LIST that doesn't include both host
and crate) in your .login file
- check that your startup script doesn't have access restrictions in it
(but that, by itself, would make it halt later if I remember correctly)
Hope this helps,
Maren Purves
(it shouldn't be dependent on architecture)
Mvme167-35b Li Jingyi
Prev: Mvme167-35b Li Jingyi
Next: Re: Mvme167-35b Li Jingyi
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
