We (the D0 experiment at Fermilab) are in the process of building
EPICS record support for several complex devices and have encountered
a few difficulties whose solutions does not seem to be covered in the
Application Developer's Guide. There are two which are of immediate
interest.
First, there are several fields in a record which reference arrays
(as in the waveform record) for which we need the actions associated
with both the SPC_DBADDR (because the fields are arrays) and SPC_MOD
(because a "put" to the field must result in a transfer to the
hardware device). Is it possible to specify both actions in the record
"dbd" file? If not, how can the equivalent effect be realized?
A possible alternative appears to be setting the "process passive"
attribute for the field and then, during record processing, using the
value in the PUTF field, which indicates when a dbPutField caused
record processing, and the dbGetFieldIndex function to determine which
field is associated with the action. This, however, feels to me like a
"hack" to handle a "special" action in record processing.
The second difficulty concerns special processing when the field is
accessed by dbGetField. Some hardware registers have destructive read
properties; the top of a FIFO stack is one example. This is an
instance when the hardware register should be read only when there is
a explicit request for the information and not periodically polled,
which seems to be the general EPICS philosophy. The problem appears to
derive from an EPICS assumption that a dbGetField access should not
cause either record or special processing. I presume that this
originated in the difficulty associated with returning a value after a
possibly asynchronous action by the device support level.
One solution is to introduce a dummy field in the record for which a
dbPutField would cause the hardware register to be read. This would be
followed by a dbGetField to another field which contains the value
which was just read. I find this option distasteful because it
requires two separate transactions over the network to accomplish a
simple read of a register; and, since the two actions are not
"atomic", there is the usual problem of two users interleaving their
caPut/caGet sequences with the subsequent loss of one reading.
Any suggestions or clarifications on these issues would be greatly
appreciated.
Fritz Bartlett
- Re: Two questions about EPICS record support Andrew Johnson
Re: pop-up menu problems in MEDM 2.3.4a [Resolution] Ken Evans
Re: Two questions about EPICS record support Tim Mooney
<1998>
2025
2026
<1998>
2025
2026
