1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA at LynxOS/x86
To: [email protected]
Date: Fri, 18 Sep 1998 18:38:44 +0700 (NSD)
Dear Madam/Sir,
I compile  R3.13.0.beta12 at LynxOS/x86 platform, LynxOS is real time
UNIX ( www.lynx.com).
1.---------------------------
"make install.host" was finished, I start "caRepeater &" which reports that
CAC: 13 if fnd
CAC: if fnd sl0
CAC: if was down
CAC: could not obtain if flags
CAC: if fnd sl2
AC: if was down
CAC: if fnd lo0
CA Repeater: failed during initialization - no local IP address
"netstat -di" showed that
Name  Mtu   Network     Address            Ipkts Ierrs
sl0*  296   <Link>                             0     0
sl7*  296   <Link>                             0     0
lo0   1536  <Link>                            74     0
lo0   1536  loopback-ne localhost             74     0
smc0  1500  <Link>0.0.c0.d5.48.f9             77     0
smc0  1500  private.net FEL-lynxos1          77     0
SLIP devices is sl0-sl7 with "down" status , Ethernet card is
smc0  with "up" status (IP=192.168.3.12).
I used the standard CONFIG_ENV with next parameters
EPICS_CA_ADDR_LIST=""
EPICS_CA_AUTO_ADDR_LIST=YES
2. --------------------------------------------
Next step, SLIP devisces has "up" status, caRepeter workes.
3.--------------------------
I rebuilt the libraries libCom.a and libca.a with a new settings
EPICS_CA_ADDR_LIST=192.168.3.12
EPICS_CA_AUTO_ADDR_LIST=NO
SLIP devices is "down", Ethetnet interface is "up".
caRepeter does not finds IP address.
I the sequence of network devices is inverse at LynxOS.
lo0 is first device.
Could you explain me the way for solution  of this problems?
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev  11
630090, Novosibirsk, RUSSIA
fax     +7 3832 342163
phone   +7 3832 359977
Prev: Re: Two questions about EPICS record support Andrew Johnson
Next: edif executable file Jin Yu
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Two questions about EPICS record support Tim Mooney
Next: RE: CA at LynxOS/x86 Jeff Hill
