1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: bug report
To: "EPICS-tech-talk (E-mail)" <[email protected]>
Date: Thu, 24 Sep 1998 12:44:06 -0600
All
We have recently discovered a bug where the 3.12 CA clients do not disconnect
from an IOC when the client's last channel on this IOC is deleted. If the client creates a
new channel on this IOC it will continue to reuse the connection that was not closed,
but if the client continues to run with no channel on this IOC then the connection
will remain open. When the client quits then all connections to IOCs are
closed. So this problem is mostly benign, but it could cause IOC resource consumption
that is higher than in past releases.
Symptoms:
In the IOC "casr" reports "Channel Count=0" for one or more clients.
Versions:
EPICS R3.12 beta9 - R3.12 beta12
Associated clients (all of the following must be true):
o clients that run continuouly for extended periods without exiting
o clients that delete channels routinely during operation (prior to exiting)
	- dm and medm are likely candidates
o clients that connect to multiple (probably many) IOCs
Impact:
o memory and file descriptor consumption load on IOCs could be higher
o note however that EPICS 3.12 in general uses less IOC memory for clients than
in the past
Jeff
______________________________________________________
Jeffrey O. Hill                      Internet     [email protected]
LANL MS H820                    Voice         505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: Re: Which MEDM Karen S. White
Next: Channel counts? Peregrine McGehee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Supported hardware Mark Rivers
Next: RE: bug report Jeff Hill
