1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform Scale Factors
To: Paul Sichta <[email protected]>, [email protected]
Date: Wed, 30 Sep 1998 16:21:25 +0200
Hello Paul,
I had the same problem and solved it by extending the waveform record
with the following fields:
field(YMUL,DBF_DOUBLE) {
	prompt("Vertical Scale Factor")
	special(SPC_LINCONV)
	interest(1)
	initial("1")
field(YZER,DBF_DOUBLE) {
	prompt("Vertical Offset (EGU)")
	interest(1)
field(ROFF,DBF_LONG) {
	prompt("Raw Offset")
	interest(1)
Record support and device support for Tek TDS540/784C have been extended
according to the new fields. The resulting record type is now called
swfRecord (for Scalable WaveForm). If you are interested I will send you
the sources.
	Ben
The Notorious Neb Nesknarf
@BESSY II: fax: +49 30 6392-4859 phone: +49 30 6392-4865
make sure useless people get employment: BND MAD Waffen Lieferung ETA
Lybien Irak Iran CIA killer Heroin Befreiungsfront IRA RAF PKK Kurden
Waveform Scale Factors Paul Sichta
Prev: Motif 2.1 and EPICS Christopher Larrieu
Next: Re: Waveform Scale Factors Steve Lewis
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Waveform Scale Factors Paul Sichta
