Garrett,
re.. When I type "pf 0" I get "f0"
It sounds like you have the parity or bit count wrong
on the serial connection to the 162. Make sure you
the workstations serial port is set for 8bits, no parity.
re.. switching to 4800
If you have a 162-5xx board this should not be necessary.
It can handle a 9600 baud download.
re..isn't there a way to dump it from one 162 to another?
> Till Straumann <[email protected]> wrote...
> You want to program the flash memory of one or multiple mvme152-532FX
> cards? Here is how you can use the VME bus to make copies of an already
> written board's flash memory:
> http://www-csr.bessy.de/control/Hard/IOC/bootpromDoc.html . This saves a
> lot of time if you have to write multiple boards, but because it's so
> easy, you might do it the fast way for any number of cards.
Joe Sullivan
APS/XFD
- Flash programming on 162 Garrett D. Rinehart
Re: Flash programming on 162 Graham Waters
<1998>
2025
2026
<1998>
2025
2026
