1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: linear conversion in ai & ao records
To: [email protected]
Date: Fri, 06 Nov 1998 12:45:37 +0100
Hi people.
What I find quite confusing about the _analog_ in/out records is the
fact that the converted value presented to device support is actually a
LONG INT. If device support wants to use the DOUBLE 'oval' it can't use
the  conversion facility. I'd suggest to make available the converted
(double) value in the future. (In order not to break existing software,
an additional field would be required.)
Best regards, Till.
Prev: Keck portable CA server usage William Lupton
Next: Re: Keck portable CA server usage saa
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: linear conversion in ai & ao records Tim Mooney
Next: FW: Ada vs C/C++ Jeff Hill
