1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Epics build system does not support cross compilers for host builds?
To: [email protected]
Date: Tue, 24 Nov 1998 15:37:42 -0600
Am I correct in thinking that the Epics build system does not support
I am trying to set up a system where a single computer (i586-linux) is
used to build epics host tools for several different host
architectures.  I have configured egcs as a cross compiler for each
desired architecture (ppc-linux, m68k-linux & sparc-solaris) and can
cross compile and link test programs for each.  The problem comes when I
try to build epics - the build system makes no distinction between tools
such as 'aitGen' & the epics modified 'flex' & 'antelope' which are used
during the build process and should be compiled & executed natively and
the tools which appear in the final epics build - such as 'excas',
'libca' etc. which should be cross compiled.
Guy Jennings
BESSRC CAT, ANL
Prev: Re: Slow loading of symbol table on MVME162 Mark Rivers
Next: MPF Release 1.0 (Hideos Replacement) Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caerr.h typo Jeff Hill
Next: Re: Epics build system does not support cross compilers for host builds? Guy Jennings
