1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ????kernel work queue overflow error????
To: [email protected]
Cc: [email protected], [email protected]
Date: Thu, 3 Dec 1998 13:03:15 -0600
Dale,
> We just experienced a bizarre occurrence with our beamline vme crate.
> Suddenly, it started to spontaneously reboot over and over, each time
> giving the message "WorkQ Panic. kernel work queue overflow", near the end
> of the process of loading all our databases, etc.  This continued until we
> turned the crate off. I would appreciate any info about where this might
> come from and/or how to test if conditions are leading to this state.
> We recently switched to an mv162 from an mv167, ...
I had a very similar problem a couple of weeks ago.  It turns out that the
Markfile in the ioc directory had ARCH defined for mv167 rather than mv162.
It was thus booting the wrong version of vxWorks, not a pretty sight.
I also have had problems with:
    - Boards not seated completely
    - The APS A32Vme module (position monitors, etc.) had problems on the
      mv162, probably because the default base address doesn't work with the
      162 BSP.
                                        Mark Rivers
Prev: Re: ????kernel work queue overflow error???? J. Frederick Bartlett ([email protected])
Next: enhancements to Andrew Johnson's IPC driver Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
