Subject: |
RE: enhancements to Andrew Johnson's IPC driver |
[email protected] (Jeff Hill) |
To: |
"EPICS-tech-talk (E-mail)" <[email protected]> |
Date: |
Mon, 7 Dec 1998 14:42:07 -0700 |
On Monday, December 07, 1998 10:08 AM, Marty Kraimer [SMTP:[email protected]] wrote:
> Jeff Hill wrote:
> > 2) I propose that the master source for Andrew Johnson's IPAC driver be moved
> > into the CVS repository at APS under a new drivers directory so that it can easily be
> > maintained by multiple sites.
> This should not be put into epics base. The cvs directory has a directory
> epics/unbundled. Maybe we should start a directory?
> epics/unbundled/base/hardware
> This can contain subdirectories for various hardware support packages. Each
> package could be structured like a <top> level application. Each package can
> follow it's own release schedule.
> Marty Kraimer
Sounds good. This is what I had in mind. However is there a good reason to
use "base" in the directory path? why not use just "epics/unbundled/hardware".
It wouldn't hurt to pre-create some of the underlying directories so that we don't
end up with a flat directory structure underneath of "epics/unbundled/hardware".
For example:
"epics/unbundled/hardware/fieldbus/allenBradley/rio" (allen bradley IO modules)
"epics/unbundled/hardware/fieldbus/allenBradley/df1"
"epics/unbundled/hardware/fieldbus/allenBradley/can" (can modules here)
"epics/unbundled/hardware/vme/timing"
"epics/unbundled/hardware/vme/binary"
"epics/unbundled/hardware/vme/ipaccarrier"
"epics/unbundled/hardware/vme/rio" (allen bradley scanner)
"epics/unbundled/hardware/isa/ipaccarrier/atc40"
"epics/unbundled/hardware/ipac/fieldbus/can"
"epics/unbundled/hardware/ipac/analog"
Jeff
Re: enhancements to Andrew Johnson's IPC driver Pete Jemian
RE: ppc Jeff Hill
<1998>
2025
2026
PC Fonts.... Bonnie Madre
<1998>
2025
2026
