On Thu, 17 Dec 1998, Ralph Lange wrote:
> > Creating directory exampleApp
> > Copying file /usr/util/epics/base/templates/makeBaseApp/top/exampleApp/Makefile -> exampleApp/Makefile
> > Not a directory Copying /usr/util/epics/base/templates/makeBaseApp/top/exampleApp/Makefile/.wind -> exampleApp/Makefile/.wind at /usr/util/epics/base/bin/sun4/makeBaseApp.pl line 249.
> This is even stranger than I thought.
> Which version of perl are you using? makeBaseApp needs perl 5. If you're
> calling makeBaseApp.pl directly from the command line, the first perl in
> your PATH will be used.
perl -V gives:
Summary of my perl5 (5.0 patchlevel 4 subversion 3) configuration:
Platform:
osname=sunos, osvers=4.1.4, archname=sun4-sunos
uname='sunos ler014.ph 4.1.4 1 sun4m '
hint=recommended, useposix=true, d_sigaction=define
bincompat3=n useperlio=undef d_sfio=undef
Compiler:
cc='gcc', optimize='-O', gccversion=2.7.2.2
cppflags='-I/usr/local/include'
ccflags ='-I/usr/local/include'
stdchar='unsigned char', d_stdstdio=define, usevfork=true
voidflags=15, castflags=0, d_casti32=define, d_castneg=define
intsize=4, alignbytes=8, usemymalloc=y, randbits=31
Linker and Libraries:
ld='ld', ldflags =' -L/usr/local/lib'
libpth=/usr/local/lib /lib /usr/lib /usr/ucblib
libs=-lnsl -ldbm -ldl -lm -lc -lposix
libc=/lib/libc.so.1.9.2, so=so
useshrplib=false, libperl=libperl.a
Dynamic Linking:
dlsrc=dl_dlopen.xs, dlext=so, d_dlsymun=undef, ccdlflags=' '
cccdlflags='-fpic', lddlflags='-assert nodefinitions -L/usr/local/lib'
Characteristics of this binary (from libperl):
Built under sunos
Compiled at Oct 23 1997 09:53:25
@INC:
/usr/local/lib/perl5/sun4-sunos/5.00403
/usr/local/lib/perl5/site_perl/sun4-sunos
> Is there a file called .wind somewhere under your EPICS base tree? Could it
> be that some weird mode bits of a file called .wind cause perl's find to go
> beserk?
I get no result from the command: "find . -name .wind -print" executed
in directory above base.
> Anyone else any idea?
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362 423-574-1268 (fax)
- Re: R3.13.1 Ralph Lange
<1998>
2025
2026
<1998>
2025
2026
