1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: alarm handler
To: "'Geoff Savage'" <[email protected]>, epics tech-talk <[email protected]>
Date: Wed, 20 Jan 1999 11:24:38 -0700
Geoff,
When EPICS Channel Access (CA) initializes it builds a list of IP addresses
that are used for CA process variable search requests and for CA beacons.
CA first queries all of the network interfaces on the local host for their broadcast
addresses using ioctl() if EPICS_CA_AUTO_ADDR_LIST is set to "YES".
Next any addresses in the environment variable EPICS_CA_ADDR_LIST
are appended to the list. If after performing these two steps the address
list is still empty then you will see the message below.
I suspect that something isnt working correctly with the network interface
ioctl() calls on your SGI host. Until the ioctl() problem is resolved you can
hand configure your SGI systems search / beacon address list with the
EPICS_CA_ADDR_LIST environment variable.
Perhaps someone with SGI experience can comment on there are known
network interface query ioctl() related issues on SGI?
There is documentation on CA configuration in the CA reference manual and also in the
site specific configuration files in base/config.
Jeff
On Tuesday, January 19, 1999 3:36 PM, Geoff Savage [SMTP:[email protected]] wrote:
> When running ALH I received this message from CA.
> ALH configuration file:
> GROUP   NULL    ICD_TEST
>     CHANNEL ICD_TEST    catest.VAL
> Execute ALH and load configuration file:
> 221:d02ka:alh > alh &
> [3] 842474
> 222:d02ka:alh >
> CA.Client.Diagnostic..............................................
>     Message: "The search request/beacon address list was empty after
> initialization"
>     Severity: Warning
>     Source File: ../iocinf.c Line Number: 701
> [3]    Done                          alh
Prev: base/src/gdd/dbMapper.cc bug saa
Next: X-terminals & EPICS security Paul Sichta
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: alarm handler Geoff Savage
Next: FW: comp.os.vxworks newsdigest Jeff Hill
