Jeff Hill wrote:
> In the past long boot delays have been observed when an IOC comes up and reuses
> the same IOC side dynamically assigned TCP port that it was using in the past. In this situation
> some IP kernels on the server side detect out of order TCP/IP sequence numbers but will
> not disconnect until a long time out has expired. I don't know why changing the version of EPICS
> would have any impact on this. Apparently this behavior varies with the version and vendor
> of the IP kernel.
In this circumstance though the long delay seems to be on access to
every file, and I thought the symptoms Jeff described only occurred once
at startup (I may be mistaken though).
Garrett - are you booting using rsh or ftp? If rsh, check that the
.cshrc file isn't taking a long time to execute - every time vxWorks
wants a file, it has to start a new shell on the host.
- Andrew
New country, new job, new address, new .signature; same old Andrew
Johnson
- RE: Slow booting ioc Jeff Hill
<1999>
2025
2026
<1999>
2025
2026
