1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Notes on building extensions against R3.13.1 base
To: [email protected]
Date: Mon, 01 Feb 1999 14:44:09 -0800 (PST)
Hello -
Several people asked for my notes on building extensions against R3.13.1 base:
Rough notes for building R3.13.1 extensions:
- Used old-style config files.
- Built WITHOUT sdds or tcl (barebones extensions).
- Started with the source and config files from our
  R3.13.0.beta4 area.
- Still built the old archiver since it has files used
  by other extensions.
- We use edd/dm instead of medm.  We don't use burt.
- Built the following extensions (in CONFIG_EXTENSIONS):
  DIRS =alh camonitor edif db2capsym dbst ezca ca libUnix \
	motifButton namecapture \
	Ezca ar cau km \
	probe \
	StripTool opi
  Note that not all of these come with the standard extensions
  tar file (notably db2capsym, dbst, StripTool, and opi).
(1) In addition to the changes required in CONFIG_SITE.Unix.solaris
    and CONFIG_EXTENSIONS, changed the UNIX_INCLUDES line in
    CONFIG.Unix.solaris to be:
    UNIX_INCLUDES = -I. -I.. -I$(EPICS_BASE_INCLUDE) -I$(EPICS_BASE_INCLUDE)/os/$(HOST_ARCH)
(2) Also changed the ARCH_DEP_LDLIBS line in CONFIG_ARCH.solaris to be:
    ARCH_DEP_LDLIBS = -lsocket -lnsl -lgen -lw -lintl -Bdynamic -ldl -Bstatic
    (Similar to what is done in base/config/CONFIG.Host.solaris).
(3) nextFieldSubr.c has been pulled out of base but is still used in some
    extensions.  Rescued it from R3.13.0.beta11 base/src/libCom and
    added it to extensions/src/libUnix.  Updated libUnix's Makefile.Unix
    for it.
(4) Removed arrtk from extensions/src/ar/Makefile since it needs tcl/tk
    and it's not needed by any other extension.
(5) In arCSCheck.c in extensions/src/ar/ar/arCSCheck.c, commented out
    the line using TS_EPOCH_YEAR (no longer defined in the base include
    files).
(6) In extensions/src/ca/Makefile.Unix, removed all references to
    cavget, cavput, cawait, and pvMultList since they need sdds (and
    nobody here uses these tools).
(7) To get nextFieldSubr from libUnix:
    - in extensons/src/cau/Makefile.Unix, changed USR_LDLIBS to:
      USR_LDLIBS = -lpprsyd -lUnix -lca -lCom
    - in extensions/src/opi/rti/Makefile.Unix, changed DM_EXTENSIONS_LIBS to:
      DM_EXTENSIONS_LIBS =  -lgz -lutil -lmenu -lpprsyd -lprintUtils -lUnix
Stephanie Allison
Prev: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) Rozelle Wright
Next: EPICS Meeting '98: Presentations Ralph Lange
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) saa
