1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: My fix to CA on alphas
To: "'Geoff Savage'" <[email protected]>, epics tech-talk <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 11 Feb 1999 16:54:06 -0700
Geoff,
My initial message on the proper consistent use of EPICS C type "dbr_long_t" with
type DBR_LONG is still valid. Ehhh, However ...
After a closer inspection of this particular change I now see that you
are making  a valid fix for a 64 bit specific bug which has existed at least
since 3.12.
Perhaps the standard tests have not been run on the alpha architecture
(and this data type has not been used with a put before on the alpha)?
Could you verify that "ca_test <channel name>" reproduces this bug before
the fix is applied?
I have committed your change (and several similar fixes) into CVS at APS.
Sorry about the confusion.
Now if there was only an undo for that mail send button...
Jeff
On Thursday, February 11, 1999 4:27 PM, Jeff Hill [SMTP:[email protected]] wrote:
> On Thursday, February 11, 1999 1:36 PM, Geoff Savage [SMTP:[email protected]] wrote:
> > I moved to the libCom directory and built libCom.a.  Then I went to the ca
> > directory and made one minor change.
> > <d0ola> diff access.c access.c.orig
> > 1915c1915
> > < *(dbr_long_t *)pdest = htonl (*(dbr_long_t *)pvalue);
> > > *(long *)pdest = htonl (*(dbr_long_t *)pvalue);
> > <d0ola>
RE: My fix to CA on alphas Geoff Savage
Prev: RE: My fix to CA on alphas Jeff Hill
Next: RE: My fix to CA on alphas Geoff Savage
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
