1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAMAC binary inputs
To: "john sinclair" <[email protected]>, "tech talk" <[email protected]>
Date: Tue, 16 Feb 1999 08:38:35 -0500
If you are using the Hytec 2992 Serial Highway driver, you can use a Binary
Input,  MBBI,  or Long-In record with DTYP set to CAMAC.  LANL also has
device support for a few models of digital input module.
To minimize CAMAC I/O,  I use the Long In record with DTYP = CAMAC to get
all 24 bits.  Then,  through database links I use the VAL field to several
MBBI records,  where I can define (single or multiple) bit groups offset
from bit 1(lsb).
-ps
-----Original Message-----
To: tech talk <[email protected]>
Date: Monday, February 15, 1999 5:11 PM
Subject: CAMAC binary inputs
>What is the standard set of records used to interface to
>a CAMAC 24 bit binary where the objects of interest are single
>bits? The multi-bit records handle only 16 bits. Is there a
>record type that holds 32 bits and also contains two 16 bit
>fields for accessing the high and low words? Thanks in advance.
>John Sinclair
>[email protected]
>Oak Ridge National Lab
>423-576-6362   423-574-1268 (fax)
Prev: CAMAC binary inputs john sinclair
Next: Linux version CapFast Dr. Chong Lee
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
