1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record support question
To: Jennifer Dunn <[email protected]>
Cc: [email protected]
Date: Fri, 26 Feb 1999 07:27:14 -0600
Jennifer Dunn wrote:
> Hi,
> I am creating a custom record, and have defined a field in the record to
> have special processing at run time (special = SPC_MOD) and have the pp_value
> set to YES (a passive record should be processed when Channel Access writes
> to this field).
> In the record support code I have a routine called special, that simple sets
> a flag to indicate that the record was accessed - and then expect that
> after special the "process" routine should be called.
process is not called as a result of a put to a special field.
If you want the record processed then, after the second call to special, call
scanOnce.
Marty Kraimer
Record support question Jennifer Dunn
Prev: Turbo PMAC and PMAC-2 cards / MACRO interface Martí Pi
Next: Re: Record support question Tim Mooney
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Record support question Jennifer Dunn
Next: Re: Record support question Benjamin Franksen
