1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASLO initial values
To: [email protected] (Rozelle Wright)
Cc: [email protected] (EPICS Tech-Talk)
Date: Mon, 1 Mar 1999 11:15:47 +0100 (MET)
--- Begin Message ---
> I am really confused about the initial values of ASLO for ai and ao
> records.
You are right - the situation is a bit confusing.
> In the record reference manual it says that the
> initial value for ai and ao are 1.0.
> The results are:
> ASLO has a default of 0   for ao records and
> 	 a default of 1.0 for ai records.
Right. But a glance at the code might clarify the situation:
aoRecord.c (~line 192):
       case(0): /* convert */
            value = (double)pao->rval + (double)pao->roff;
            if(pao->aslo!=0.0) value *= pao->aslo;
            value += pao->aoff;
aiRecord.c (~line 365):
        val = (double)pai->rval + (double)pai->roff;
        /* adjust slope and offset */
        if(pai->aslo!=0.0) val*=pai->aslo;
        val+=pai->aoff;
So there's no real difference between ASLO being not set, 0.0 or 1.0.
(Actually ASLO being 0 saves a few usec for the multiplication.)
> I am putting 1.0 as the value of ASLO in all the capfast symbols
> that we are using for both ai and ao records, which seems to be the
> right way to go to me.
Generally agreed.
We could actually have a default of 1.0 for ao records in the dbd file and
get rid of the test against zero in the code.
Or we could have a default of 0 for both record types and define the value
0 for ASLO as "don't use it". (This would need a word in the doc.)
Should we do something? Is this worth the effort? *Shrug.*
Ralph
--- End Message ---
ASLO initial values Rozelle Wright
Prev: ASLO initial values Rozelle Wright
Next: Re: Record support question Benjamin Franksen
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: HP-UX 10.20 (hp700) Extensions Binaries Ralph Lange
