1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Slow initial connection using Simple Channel Access
To: "'Dale L. Brewe'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 12 Apr 1999 10:12:39 -0600
Dale,
Certain versions of the early Winsock II libraries under windows 95 had bugs that
resulted in symptoms of this nature, but to the best of my knowledge these versions
are never installed into windows NT. NT supplies a version of the winsock II
DLL that includes the bug fix for this problem, and layered products installation should
not replace this DLL with an earlier version.
Symptoms like this might also occur if you have a poorly terminated Ethernet, or
some other network hardware problem.
I do not see a problem of this nature here. However, I am not using SCA and the version
of the CA DLL's from Chris's web site may be based on a slightly different version
of EPICS than we are using here.
Jeff
On Friday, April 09, 1999 8:52 AM, Dale L. Brewe [SMTP:[email protected]] wrote:
> I've been using the Simple Channel Access libraries under NT, and have
> noticed that the time to make an initial connection is quite long. For
> example, using the routine cache_getbyname, it takes about 45sec to get 140
> values initially (~0.33sec/value). I've also tried the batch routines
> que_get and do_get, with a marginal improvement (to ~0.25sec/value), which
> is still pretty difficult to live with. Can anyone tell me if they have a
> similar experience? Is this an inherent limitation of these
> functions/library, or is it possible to improve the performance? My ioc
> uses epics 3.13beta11 and my client (based on LabVIEW) has used sca3.dll
> and ca.dll for 3.13.0 and previous versions.
> Thanks
> Dale Brewe
>  Dale L. Brewe     PNC-CAT/U. of Washington
>  ph: 630 252 0582         fax: 630 252 0580
>  Mail:
>  APS/Argonne National Laboratory
>  Bldg 435E sector 20
>  9700 S. Cass Ave.
>  Argonne, IL 60439
Prev: Re: Slow initial connection using Simple Channel Access Dale L. Brewe
Next: Evaluation of Java for Use in Control Systems Mike Oothoudt
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
