1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MV167 serial port
Date: Mon, 10 May 1999 09:49:38 -0600
On Monday, May 10, 1999 10:13 AM, Philip Taylor [SMTP:[email protected]] wrote:
> Is it possible to use the serial port(s) on an MV167 directly
> from EPICS?
Yes
> I can see there's an EPICS driver called drvSerial
> at Keck - is this, or something else, suitable?
The drvSerial code uses the C STDIO library to communicate
so it works with any serial device that has a vxWorks
serial device driver. This code provides only queuing
and framing services. Allen Honey at Keck has a driver which
is layered on drvSerial which can be configured to communicate
with serial devices that communicate over simple command line
ASCII based protocols. There are also a number of drivers for
specific devices which use drvSerial.
Jeff
Prev: Re: gpib device Bill Brown
Next: MV167 serial port Philip Taylor
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gpib device Noboru Yamamoto
