1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StripTool-2-4-b6
Date: Wed, 12 May 1999 17:30:05 -0400
Ron,
  There's a new version, StripTool-2-4-b7, at
ftp://ftp.jlab.org/pub/epics/stripTool which fixes this
problem.  Albert Kagarmanov at DESY had noticed this
quite some time ago, and also supplied the fix.
  This newer version also handles out-of-memory conditions
on the X server more gracefully, which allows you to
recover if, for example, you resize the window when there
is not enough server memory to create an appropriately-sized
pixmap.  In previous versions, the X toolkit would simply cause
the program to exit.  Now you'll get a message indicating the
problem so that you can restore the window to its previous
(non-pixmap-hoggin') size.
  Additionally, this code provides greater configurability
via X resources.  In addition to the standard X resource
handling, you can create site and user-specific defaults
files to configure such things as axis and legend fonts,
X-axis tic strategy, and various other things.  Look at the
file StripFallbacks.h for some other resources.  The site
default file can be set by an environment variable,
$STRIP_SITE_DEFAULTS, and the user file is ~/.StripToolrc.
  Thanks for the feedback.  FYI, here are the things which
I want to accomplish before calling this a "release" (i.e.
non-beta) version:
  1. redraw code optimized for large data sets
  2. verify interoperation with archiver
  3. On-line user's documentation (also, coder's documentation
     for history "plug-in")
  4. explicit buffer settings (memory / timespan), separate from
     actual display range
  5. some more testing
Chris
Christopher Larrieu
Jefferson Laboratory
(757) 269-5097
Prev: StripTool-2-4-b6 Ron Chestnut
Next: Silent death of an IOC Nick Rees
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
