Subject: |
Re: PowerPC and dbpr |
Nick Rees <[email protected]> |
Date: |
Wed, 19 May 1999 08:18:24 -1000 (HST) |
Kevin,
> Is it the general consensus to just disable floating point
> exceptions as a whole? Has anyone been looking into actually
> getting to the root of these problems? Or is it just me?
I have had similar problems with MIPS architecture and, in general, my
approach has been to fix the bugs. Usually they are to do with
uninitialized variables or less than careful casting of pointers
leading to bad byte alignment. They are fairly easy to trace since if
you just run up the debugger and attach to the suspended task it tells
you exactly where the problem is.
Since the Bancomm 635 has my name plastered all over it I would be
interested in knowing the place where it is failing in this instance.
Cheers,
Nick Rees
Joint Astronomy Centre Ph: +1 (808) 961-3756
660 N. Aohoku Place Fax: +1 (808) 961-6516
Hilo, HI. 96720 Internet: [email protected]
Re: medm2_3_5.static Steve Lewis
Y2K Status? Paul Sichta
<1999>
2025
2026
PowerPC and dbpr Kevin Tsubota
medm2_3_5.static Paul Sichta
<1999>
2025
2026
