1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Exploding" a waveform into individual values
Date: 3 Jun 99 12:15:08 +0900
Hellor Ron,
>Hello All,
>I think I've seen the answer to this, I may have even asked the question
before.
>I have a 10 element waveform (type float) from which I wish to extract
each
>element into an individual AI.
>I could code 10 individual subArray records, each mapped to another
element, but
>a subroutine record seems easier. If my 10 element waveform VAL is linked
to A
>of the subroutine record, is the code simply:
>psub->b=psub->a[0]
>psub->c=psub->a[1], etc.?
>That seems much too easy, and "a" is not an array, right?
>/Ron Chestnut
I'm sure that one of GURUs in EPICS collaboration will answer this quesion,
but I will report what I studied anyway.
The psub->inpa field keeps a link to your 10 element waveform VAL field.
You can copy the value of the waveform record into your buffer ,
(you must allocate buffer in your subroutine),
using dbGetLink() function call, I think.
Then you can copy values into the other fields,
	psub->b=pbuf[0];
	psub->c=pbuf[1];
	etc.
Before I wrote this mail, I looked at the code of the subroutine record
(subRecord.c).
The process() function calls the fetch_value() function
to update values in the field A to L(?)
before your subroutine is called .
The fetch_value() function in the subRecord.c get values from link using:
  	for(i=0, plink=&psub->inpa, pvalue=&psub->a;
 		i<ARG_MAX;
		i++, plink++, pvalue++) {
		status=dbGetLink(plink,DBR_DOUBLE, pvalue,0,0);
I'm not sure if this call does not break subroutine record strucuture,
when plink , whic is psub->inpa in this case, is a link to array field
longer
than ARG_MAX.
Noboru Yamamoto
KEKB control group
KEK, JAPAN
Prev: "Exploding" a waveform into individual values Ron Chestnut
Next: subscribe Mathias
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: "Exploding" a waveform into individual values Marty Kraimer
