1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Successful EPICS Linux builds
Date: Tue, 15 Jun 1999 10:37:14 -0500
Thanks to everyone who responded to my initial query on Linux builds.
Two of the responses did the trick.  I have succesfully built EPICS base
R3.13.1 on a Linux host for mv162 (68k) and mv2603 (ppc).  The host
builds are done with the gcc compiler.  I briefly tested the builds
using the exampleApp.
William Lupton reminded me to override general vxworks architecture
configuration in CONFIG.Vx with specific architecture configurations in
CONFIG.Vx.$(T_A).  The other piece of information came from Janet
Anderson.  I had to change the  WIND_HOST_TYPE from Linux to
i386-linux2.
The ppc build failed on the first pass.  The problem was in
base/src/rsrv/camessage.c.  The problem occured when using variable
length argument lists.  Our vxworks guru here at Fermilab suggested that
I put the vxworks header file first.  This solved the problem.
Geoff Savage
Prev: devSup for Cockroft-Walton HV kunio koseki
Next: Changing caRepeaters Geoff Savage
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: devSup for Cockroft-Walton HV J. Frederick Bartlett ([email protected])
