1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS archiver
To: "Eugene T. Yamamoto" <[email protected]>
Cc: [email protected]
Date: Wed, 30 Jun 1999 18:55:11 -0400
> Actually, AR does a core dump. No intentional aborts as far as I can see.
> Maybe we just have a REALLY old version of AR.
It calls assert(), which calls abort() when it fails, which generates a
SIGABRT signal, which will cause a core dump if the current working
directory is writable.
See assert(3) and abort(3).
It is quite intentional, and this isn't the only place AR dies in response
to a condition which is not a true error condition.  Among other things, it
does not distinguish between a write "failure" due to the max file size
being exceeded and an actual error in writing to the file.
ARR has similar problems.  For instance, if you are retrieving data and the
file size has changed since the last retrieval, it aborts().  Using the
"resync" item in the "retrieve" menu will prevent that.  If the size
changes in the middle of the retrieve, you lose regardless.  This makes it
harder to use on a "live" archive file than it should be.
- brian
RE: EPICS archiver Jeff Hill
Re: EPICS archiver Eugene T. Yamamoto
Prev: Re: EPICS archiver Eugene T. Yamamoto
Next: EPICS on vxWorks/x86 john sinclair
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS archiver Jeff Hill
