Wow, that was quick.
I've already considered the genSub record and if nobody else has written
a suitable record I think I will use it. It seems that you can handle nearly
every I/O device with a genSub record. But 42 I/O links maybe are
full of meaning in some cases, but less would be more appropriate in my case.
Anyway, thanks for the swift reply,
regards
Andreas
Steven M Beard wrote:
> The "general subroutine" (genSub) record can handle variable sized arrays.
> The genSub record is similar to the subroutine record (in that it executes
> a user defined function) but allows multiple input fields and multiple
> output fields. Any of these fields can be a variable sized array (for
> example the size and type of input field A can be defined using fields NOA
> and FTA, and the size and type of output field VALA can be defined using
> fields NOVA and FTVA).
> You might be able to handle your waveforms using the genSub record.
> Alternately, you could take the code from the waveform output record and
> the code from the genSub record and merge them together to make your own
> waveform output record which handles variable sized arrays (unless someone
> else has already done this...).
> Steven
> Steven Beard
> UK Astronomy Technology Centre
> Royal Observatory Tel. : +44 (0)131 668 8253 (direct)
> Blackford Hill +44 (0)131 668 8100 (switchboard)
> Edinburgh EH9 3HJ Fax. : +44 (0)131 668 1130
> UK E-mail : [email protected] (Internet)
> WWW : http://www.roe.ac.uk/smbwww/
Andreas Luedeke, Controls Group, Swiss-Light-Source, PSI
mailto:[email protected], tel:+41-(0)56-310-4002, fax:-4413
- Re: writing waveform out Steven M Beard
Re: writing waveform out Ron Chestnut
Re: writing waveform out J. Frederick Bartlett ([email protected])
<1999>
2025
2026
<1999>
2025
2026
