1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: channel access time response
To: [email protected]
Date: Thu, 22 Jul 1999 09:12:22 -0500 (CDT)
I've made some channel access response time measurements between our OPI
workstations and our storage-ring bpm iocs. The measurement does cagets to
PVs in the bpm iocs. The time from issuance of the caget to the received PV
value is measured. This is not the same as the it takes for a CA client to
receive a monitor, but it's a lot easier to measure. I bin the results
in a histogram with a 100msec resolution.
The response time depends on ioc load, workstation load and network load.
Most response times are less than 100ms. About 0.25 to 1% of the time the
response time is 100 to 200 ms. Occasionally the response time exceeds 200ms.
I've seen response times out to 500-600 ms, but this is rare. Keep in mind
this measurement is UNIX<->vxWorks. I would expect (hope) vxWorks<->vxWorks
to be faster. The Unix workstations are Sun Ultras running Solaris. The iocs
are running vxWorks 5.3 on MVME172s (60MHz). The iocs are running about 50 to
70% idle. The workstations are typically busy. Sorry, I didn't note the
workstation load at the time of the measurement.
Frank
Prev: EPICS CA server and also GDD issues Jeff Hill
Next: Re: String PVs and the Portable CA Server. Brian Tieman
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: channel access time response Jeff Hill
Next: String PVs and the Portable CA Server. Brian Tieman
