Hi Brian,
>My origional attempt at getting strings to work were with aitEnumFixedString.
>My memory is foggy as to why I wasn't able to get it to work then--but I didn't
>get Fixed Strings to work either. I remember finally settling on aitEnumString
>because I was able to Put into the PV and get the put value into my code. Also,
>once Put, other clients could Get without problem.
OK, I don't allow puts (yet) so thanks for the heads-up on this.
>What I need to do now is have my server change what a client Gets based on what
>the server application is doing. I can see the appropriate string in the scan
>method for the PV, but I can't copy it into the smartGDDPointer so clients can
>see it properly. I really don't care if the PV is a aitEnumString or a
>aitEnumFixedString--I just want it to be a string. If you, or anyone else, has
>a small snippet of code from the scan method which shows how to put a string
>into a smartGDDPointer, I'd be a very happy man!
Sorry, no joy... I don't use smartGDDPointers - maybe I should be?
I use regular gdds instead.
A little bit of code that probably won't help you but I'll be a sport
and include it anyway:
>From my PV constructor:
type_e = aitEnumFixedString;
nelem = 1;
dbvalue_ps = memory allocated to hold the SLC database value
// Create general data descriptor objects for the current
// SLC database get value. Abort if allocation error.
get_po = new gdd(gddAppType_value, /* value type */
type_e, /* primitive type */
1, /* 1 dimensional array */
&nelem);
assert(get_po != 0);
// Put the pointer to SLC database data in the get GDD.
// This prevents the unnecessary copy from the SLC database
// structure to the gdd object. First define a destructor
// for the database value so that the value space is deleted
// only after all references are removed.
dbvalue_destruct_po = new SLCcasPVgddDestructor_C(dbvalue_ps);
assert(dbvalue_destruct_po != 0);
dbvalue_destruct_po->reference();
get_po->putRef(dbvalue_ps, type_e, dbvalue_destruct_po);
// Initialize timestamp in GDD. I notice the GDD init
// routine does not do this for some reason. Also, initialize
// status/severity to indicate that data is undefined.
const aitTimeStamp * time_po = getCurrTime();
get_po->setTimeStamp(time_po);
get_po->setStatSevr(UDF_ALARM, INVALID_ALARM);
>From my PV destructor:
if (get_po)
get_po->unreference();
get_po = 0;
// Dereference the DB value destructor. It'll be freed as soon
// as EVERYONE has dereferenced.
if (dbvalue_destruct_po)
dbvalue_destruct_po->destroy(0);
dbvalue_destruct_po = 0;
dbvalue_ps = 0;
In the PV read method, the data area, status, severity, and timestamp are
updated. The read function table routine for getting a value is then simple:
caStatus SLCcasPV_C::getValue(gdd &value_ro)
{ value_ro.put(get_po); return S_cas_success; }
There is code for monitoring but I'll leave it out.
Hope you get better help from somebody else!
Stephanie
Re: String PVs and the Portable CA Server. Brian Tieman
How do you know if you are accessing a shared resource? Steven M Beard
<1999>
2025
2026
RE: String PVs and the Portable CA Server. Peregrine McGehee
FW: NI VXIpc SBC and VxWorks Jeff Hill
<1999>
2025
2026
