Hello Arch,
I have had this experience with 167s, caused by something in the
shell's startup script that the booting IOC can't do. This might
explain why you had the problem after changing shells, and why
the 167 works when you use ftp.
Possibilities:
1. The user startup script on the host includes calls to commands on
a server that the IOC does not have access to.
2. The user startup script prints out something while coming up,
either a planned message or an error message.
3. The startup script contains a tcsh command that csh does not
have, causing an error message as in 2.
So I recommend checking the .cshrc for the account that
the IOC uses, and either removing or if'ing out the offending lines.
Hoping this helps,
Susanna
On Saturday, 24 Jul 1999, Lin Jie <[email protected]> wrote:
> I changed my host computer from tcsh back to csh, and I found all the 162s
> that are booting from my host stop loading. Two different cases: One is if my
> IOC using the rsh, then it will say "bus error" and print out bunch of
> things. The other is if my ioc is using the ftp (user name + passwd), then it
> will hang up when it tries to load the VxWorks symbols.
> What realy bothers me is that this only happens to 1162. I have 167s as well
> which are uing rsh. It has the same "bus error", but when I put in the passwd
> to yse the ftp, then it loads no problem.
> Before, the experience that I had is that if I use the ftp, then the 162 will
> hang up, now, this time, it's the other way around.
Susanna Jacobson MS 10-110
[email protected] Lawrence Berkeley National Laboratory
VOICE: (510) 486-7801 1 Cyclotron Road
FAX: (510) 486-7374 Berkeley, CA 94720
mbbiDirect record Leonard J. Reder
Re: GreenSpring IP-DAC driver? Graham Waters
<1999>
2025
2026
Re: bug in EPICS R3.13 and R3.12---booting vme162 Andrew Johnson
Re: bug in EPICS R3.13 and R3.12---booting vme162 William Lupton
<1999>
2025
2026
