Re...
> Suppose, for the sake of this
> example, you take a genSub record with an integer output
> | genSub |
> | +-OUTA-
> FTVA: LONG
> SNAM: myFunction
> and your user defined function writes to its VALA field like this
> long myFunction( struct genSubRecord *pgensub )
> *(long *)pgensub->vala = value;
> return 0;
> I ... saw some very
> strange behaviour (a different record generating an "illegal choice"
> message when I tried to write a valid value to one of its inputs) until I
> explicitly protected pgensub->vala with a mutex semaphore.
> Any advice gratefully received.
Wait a minute... *pgensub->vala is not a shared resource unless two gensub records
have the same value for pgensub->vala, and that would indicate an error in the
initialization of vala (unless you're trying something tricky).
Anyway, for whatever it's worth, I've seen illegal-choice messages in only two
situations: 1) mismatch between the .dbd file and the code; and 2) somebody
stepping on somebody else's memory.
Tim Mooney
Re: bug in EPICS R3.13 and R3.12---booting vme162 Andrew Johnson
Y2K Bill Cruise
<1999>
2025
2026
Re: How do you know if you are accessing a shared resource? William Lupton
bug in EPICS R3.13 and R3.12---booting vme162 Lin Jie
<1999>
2025
2026
