Hi Len,
As you might know, channel access has an array size limit of 16 Kbytes
which greatly impedes passing images around via channel access.
To overcome this, I developed an "image record" which treats each
scan line of an image as an array. The image record has fields defined
for each scan line (e.g. imageRecord.L1, imageRecord.L511, etc). CA clients
can retrieve the entire image by reading N arrays (where N is the number of
scan lines). Smarter clients will read only lines that they are interested
in (region of interest) thereby reducing network traffic.
To get IDL (a client) to read an image from this record takes only a few
lines of code.
This is really for transmission between an ioc and a CA client, not
"record to record". However, a CA client running on the ioc (e.g. sequencer)
could certainly copy the necessary data to other records.
If this seems approach seems helpful, send me a note and I'll send you
the record support.
Ned
> Hi,
> I have been developing some additional device and driver support
> for EPICS and am coming up to the task of interfacing our low end
> CCD camera head to EPICS via a Raster Graphics PMC Video Capture
> module (precisely this is the RG-101 PMC Color Graphics Board with
> Video Capture).
> I am interested if anyone has developed image record code for EPICS
> which supports image acquisition. Can NTSC image data be transfered
> from record to record. My primary use for the image data is optical
> alignment. We will aquire image data of Laser and LED points and
> do centrioding on them to position optics. Would be interested if
> anyone else is doing similar types of things with EPICS.
> Regards and thanks in advance for replies,
> Len
> ____________________________________________________
> Leonard J. Reder
> Jet Propulsion Laboratory
> Interferometry Systems and Technology Section 383
> Email: [email protected]
> Phone (Voice): 818-354-3639
DM2K Thomas . Birke
Wire Scanners Gary Carr
<1999>
2025
2026
Image Processing Support Under EPICS Leonard J. Reder
medm Leonard Reder
<1999>
2025
2026
