1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: One CA server problem
To: [email protected]
Cc: [email protected]
Date: Thu, 02 Sep 1999 08:38:50 -0700 (PDT)
Hi Ralph,
>We ran across a similar problem (freezing gateway) a few weeks ago. We
>tracked it down to the CAS freezing if it was asked for a PV with
>illegal characters (in this case: German umlauts) in the PV name.
>I patched the CAS code to check every PV resolution request for illegal
>characters replacing them by 'X's and we didn't see any freezing gateway
>anymore.
OK, thanks for the fix.  I notice that our gateway process has been up
(no freezing, no restarts) since July 28!  However, it is taking a lot
of CPU probably because the BaBar clients are seething with unresolved
PVs (I still need to verify this).  I'll do one of your suggestions to
at least prevent these PVs from going past the gateway onto our PEPII
system.
Ralph, you are always so helpful!  Thanks very much,
Stephanie
Prev: Re: One CA server question Ralph Lange
Next: RE: fdManager.cc question Jeff Hill
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Arrays and portable channel access server Jeff Hill
