1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC CA client limit?
To: Paul Sichta <[email protected]>
Cc: [email protected]
Date: Fri, 03 Sep 1999 14:38:10 -0500
Paul Sichta wrote:
> When I connect more than about 24 CA clients to my IOC they don't connect
> and I get the errors shown below (IOC console display first,  medm error on
> workstation below that).   spy  shows the CPU is ~90% idle and   memShow
> shows ~20Mbytes free.  Is there a numerical-limit on how many clients the
> server will accept ?
> IOC>0x1b23070 (CA TCP): CAS: Client accept error
> S_iosLib_TOO_MANY_OPEN_FILESf
There is a numerical limit on the number of open files, and each TCP/IP
socket is an open file.  You can increase this by rebuilding your vxWorks
boot image.  Edit <tornado>/target/config/all/configAll.h and change the
#define NUM_FILES from 50 to something larger - we use 150 here at APS.
Save, then run make in the config/<arch> directory to rebuild the vxWorks
image and reboot.
- Andrew
Complexity comes for free, Simplicity you have to work for.
IOC CA client limit? Paul Sichta
Prev: IOC CA client limit? Paul Sichta
Next: vxgdb Dayle Kotturi
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: GPIB Support @ BESSY Benjamin Franksen
