1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problems with downloading VxWorks and Epics
To: "EPICS tech-talk" <[email protected]>
Date: Thu, 9 Sep 1999 16:03:08 +0800
Dear all,
I am trying to download VxWorks and EPICS example to MV162 from SUN solaris2.7. I have seen the VxWorks boot image on the terminal. But there is problem with EPICS.
      ]]]]]]]]]]]  ]]]]     ]]]]]]]]]]       ]]              ]]]]         (R)
 ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]       Development System
 ]]]]]]]]]]]]]]]]]]]]]]]]]]]       VxWorks version 5.3.1
 ]]]]]]]]]]]]]]]]]]]]]]]]]]       KERNEL: WIND version 2.5
 ]]]]]]]]]]]]]]]]]]]]]]]]]       Copyright Wind River Systems, Inc., 1984-1997
                               CPU: Motorola MVME162.  Processor #0.
                              Memory Size: 0x400000.  BSP version 1.1/5.
                             WDB: Ready.
Executing startup script /export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd ...
# Example vxWorks startup file
# Following must be added for many board support packages
#cd <full path to target bin directory>
cd /export/home/zheng/epicsTest/bin/mv162
syntax error
Done executing startup script /export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd
In /usr/local/tornado101/target/config/mv162/config.h, I define as follow:
#define DEFAULT_BOOT_LINE \
"ei(0,0)COSUN-01:/usr/local/tornado101/target/config/mv162/vxWorks h=159.226.222.79 \
 e=159.226.222.85 u=guest pw=control tn=MV162 f=0 \
 s=/export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd"
In <VxWorksBoot>, the parameters is :
boot device          : ei
processor number     : 0
host name            : COSUN-01
file name            : /usr/local/tornado101/target/config/mv162/vxWorks
inet on ethernet (e) : 159.226.222.85
inet on backplane (b):
host inet (h)        : 159.226.222.79
gateway inet (g)     :
user (u)             : guest
ftp password (pw) (blank = use rsh): control
flags (f)            : 0x0
target name (tn)     : MV162
startup script (s)   : /export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd
other (o)
The .../st.cmd is:
ld < iocCore
ld < seq
ld < exampleLib
#cd startup
dbLoadDatabase("../../dbd/exampleApp.dbd")
dbLoadRecords("../../db/dbExample1.db","user=zhenglf")
dbLoadRecords("../../db/dbExample2.db")
iocInit
seq &snctest
Could somebody tell me what I made the mistakes and how to solve them?
Thanks in advance.
Lifang Zheng
Re: problems with downloading VxWorks and Epics Ralph Lange
Prev: Job Opening at Argonne/APS Bill McDowell
Next: Re: problems with downloading VxWorks and Epics F. Gougnaud
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: problems with downloading VxWorks and Epics Ralph Lange
