1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Generic Fieldbus Device Support (GPIB and others)
To: <[email protected]>, "EPICS Techtalk" <[email protected]>
Date: Tue, 14 Sep 1999 16:54:49 -0600
> Dirk Zimoch wrote:
> > I've written a generic device support that should be able to talk
> > to all fieldbus devices, which do I/O as a stream of bytes.
> > I call it the Stream Device.
> This is cool! I believe this could be the ultimate replacement for
> devCommonGpib.
Another generic approach to framing protocol for byte serial devices is
drvSerial.c / devAscii.c. Both are available from KECK.
> 2) Concerning the INP/OUT field for INST_IO link type: "You have 78
> characters after the @, even though the Application Developers's Guide
> says you only have 35 characters (Version 3.13.0.beta4)."
The original CA client API unfortunately still has a built in string length
limitation of 40 characters. Removing this limitation is high up on the
priority list.
Jeff
Re: Generic Fieldbus Device Support (GPIB and others) Marty Kraimer
Re: Generic Fieldbus Device Support (GPIB and others) Benjamin Franksen
Prev: Re: Generic Fieldbus Device Support (GPIB and others) Benjamin Franksen
Next: Re: Generic Fieldbus Device Support (GPIB and others) Marty Kraimer
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
