1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mv172 in place of mv162
To: [email protected]
Date: Thu, 23 Sep 1999 10:07:58 -0500 (CDT)
I have recently upgraded some of my mv167s to mv172s with great success.
Now I am trying to upgrade an mv162 to the mv172 and having no luck.
I've got EPICS_3.13.0b11 and some home-brew code (subroutine record stuff)
running on the 162. I'm also using an IPack digital I/O module (Systran
316DIO) and a couple of the serial ports.
I switch over to load up the 172 iocCore and vxWorks. The library stays the
same since it has always been built for the mv167 and the other mv167
libraries carried over directly to the mv172.
It loads up to iocInit and then just seems to hang. Sometimes I get a few
more lines out of the startup script, but that's different each time. Up to
iocInit, everything looks perfectly normal every time. The only thing
really different between this and the mv167s I replaced is the use of the
IPack carrier. I'm assuming something is breaking there. Any ideas?
BTW: I access the IPack module directly from a subroutine (record), not
from an EPICS device layer.
Garrett Rinehart
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 S. Cass Ave
Argonne, IL  60439
(630)252-6561
Prev: Message Passing Facility - Release 1-4 Marty Kraimer
Next: Motor record version 3.5 released. Ron Sluiter
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
