"Leonard J. Reder" wrote:
> Hello all,
> I am interested if anyone in the EPICS community is utilizing a
> current technology frame grabber board with EPICS/VxWorks. The
> board must be either PMC, that is a PCI doughter card which
> plugs into, in our case, the VME Motorola MVME2307 PPC SBC. Or
> it can also be a stand alone frame grabber which connects
> directly to a VME bus.
We are using Data Translation DT1451 boards. They are VME boards
with very little on-board processing. They can do things like
add images. I have ported the DT-IRIS package to run under vxWorks,
and it provides about everything the original did. We don't use a
direct EPICS interface, but that should be easy enough to do. These
modules are no longer in the catalog, but DTI would probably make
you one. They are at http://www.datatranslation.com.
Good luck!
William L. Cruise [email protected]
Electronics System Supervisor FAX: 808 885-7288
Canada-France-Hawaii Telescope Voice: 808 885-3122
P.O. Box 1597 http://www.cfht.hawaii.edu/~cruise
Kamuela, HI 96743
- FrameGrabber For VME/PMC VxWorks/EPICS use Leonard J. Reder
Re: FrameGrabber For VME/PMC VxWorks/EPICS use Detlef
<1999>
2025
2026
<1999>
2025
2026
