1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with epics alarm
To: Sue Witherspoon <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 08 Oct 1999 14:06:24 -0500
Sue Witherspoon wrote:
> The problem is in the epics alarm subroutine:
> The comparison between a double and a float is okay as long as the precision of
> the comparison is not very large. For instance
> On the surface the solution would be to change the type of hihi to
> be double but on further inspection the ascii file for this record
> says that the field is DBF_FLOAT? Does this imply that the
> size of the record must also change?
This is a problem in more than just the ai & ao records, which I noticed a
few weeks ago.  The fix I applied to the repository was different for the
3.13 branch to that on the 3.14 development tree.  On the 3.13 branch I
just changed the type of the hyst and lalm variables in the alarm()
routine to be double, which improves the alarm handling without having to
change the DBD file.  This change will appear in the 3.13.2 release
(whenever that comes out - it'll be just a bug-fix release). For 3.14
these fields and the relevent variables in alarm() should all be made into
double, but it looks like I haven't quite finished doing that yet.
To answer Ben's point, this is all due to historical baggage.  AIUI the
original GTACS code which EPICS derives from used floats for everything.
When new devices came along that could provide extremely high accuracy and
needed greater precision, various records were converted to use doubles
but this wasn't done very well.
Personally I'd like to start again and design a complete new set of record
types which could even use a different API to the device support layer.  I
suspect this will never happen though - we'll have to continue to support
existing record types to maintain the current control systems.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Problem with epics alarm Sue Witherspoon
Prev: Re: Problem with epics alarm Benjamin Franksen
Next: Re: Problem with epics alarm Steve Lewis
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
